주요 콘텐츠로 건너뛰기
CASIO mw240-1bv Battery Replacement
필요한 것
  1. CASIO mw240-1bv Battery Replacement, Battery: 1 단계, 이미지 1/3 CASIO mw240-1bv Battery Replacement, Battery: 1 단계, 이미지 2/3 CASIO mw240-1bv Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the four screws from the back of the watch.
    • Remove the back cover of the watch.
  2. CASIO mw240-1bv Battery Replacement: 2 단계, 이미지 1/3 CASIO mw240-1bv Battery Replacement: 2 단계, 이미지 2/3 CASIO mw240-1bv Battery Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to pull the small metal piece to the right slightly to allow the battery to pop out.
    • Replace battery with a SR626SW watch battery.
    • The battery may spring out very suddenly.
    • If your battery is swollen, handle it with care and dispose of it through an e-waste center or ask an electronics store. Do not dispose of it in the garbage.
  3. CASIO mw240-1bv Battery Replacement: 3 단계, 이미지 1/2 CASIO mw240-1bv Battery Replacement: 3 단계, 이미지 2/2
    • If the rubber seal pops out, realign the rubber seal with the groove along the back face.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jasmyn McBeth
회원 가입일: 09/08/21
166 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 48
30일 전: 242
전체 시간: 5,501
