주요 콘텐츠로 건너뛰기
CCM Ice Skates Steel Blade Replacement
필요한 것
  1. CCM Ice Skates Steel Blade Replacement, Steel Blade On CCM Skates: 1 단계, 이미지 1/1
    • Place the palm of one hand over the laces at the middle of the skate boot.
    • Close that palm and firmly grasp the skate.
    • Use the other hand to grab and remove any skate guard.
  2. CCM Ice Skates Steel Blade Replacement: 2 단계, 이미지 1/1
    • Place the heel/back portion of the skate on the table.
    • Firmly grasp the toe of the skate with one hand.
    • Insert the flat head screwdriver from a multi-tool into the groove of the first screw and hold.
  3. CCM Ice Skates Steel Blade Replacement: 3 단계, 이미지 1/1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the first screw.
    • Turn the flat head screwdriver in a counter clockwise rotation until it is loose.
  4. CCM Ice Skates Steel Blade Replacement: 4 단계, 이미지 1/1
    • Remove the loosened screw from the white plastic blade holder.
    • Insert the screwdriver into the fastener and apply pressure to remove the fastener.
  5. CCM Ice Skates Steel Blade Replacement: 5 단계, 이미지 1/1
    • Insert the flat head screwdriver from a multi-tool into the groove of the second screw and hold.
  6. CCM Ice Skates Steel Blade Replacement: 6 단계, 이미지 1/1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the second screw.
  7. CCM Ice Skates Steel Blade Replacement: 7 단계, 이미지 1/1
  8. CCM Ice Skates Steel Blade Replacement: 8 단계, 이미지 1/1
    • Wrap a hand in a cloth towel.
    • Pinch the two flat sides of the metal blade between the thumb and index finger.
    • Do not touch the bottom or edges of the blade.
  9. CCM Ice Skates Steel Blade Replacement: 9 단계, 이미지 1/1
    • Apply pressure to the sides of the blade with your fingers.
    • Slowly pull the blade upward.
    • To avoid injury, do not pull the blade up in one quick motion.
결론
Steven Marcyan
회원 가입일: 10/04/17
101 평판
안내서 1개 작성함
Michigan Tech, Team S5-G9, Galliah Fall 2017 Michigan Tech, Team S5-G9, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G9
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 6,042
