주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Fan 수리는 자사의 서비스 설명서를 사용하세요.
  1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: 1 단계, 이미지 2개 중 1개 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: 1 단계, 이미지 2개 중 2개
    • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
    • Make sure the device is unplugged and fan blade is not spinning before starting.
  2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: 2 단계, 이미지 3개 중 1개 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: 2 단계, 이미지 3개 중 2개 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: 2 단계, 이미지 3개 중 3개
    • Unscrew the clip-on stand that connects the fan. This can be done by hand.
    • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
    • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
    • The switch's settings:
    • Off (center)
    • Speed 1 (left)
    • Speed 2 (right)
  3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: 3 단계, 이미지 2개 중 1개 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: 3 단계, 이미지 2개 중 2개
    • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
    • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
  4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: 4 단계, 이미지 2개 중 1개 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: 4 단계, 이미지 2개 중 2개
    • Now that the blade is removed. The motor can now be removed from the other half of the housing.
    • Remove the two screws indicated in order to take the module out of the plastic.
    • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
  5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: 5 단계, 이미지 1개 중 1개
    • That's it! There isn't too much when taking this device apart.
    • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
작성자
1다른 기여자 명과 함께
Justin
회원 가입일: 12/08/14
111 평판
안내서 1개를 작성함
4가이드 댓글
Hi How do you find the replacement switch?
sadeyealso - 답글
the switch melted….
sadeyealso - 답글
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - 답글
Is it possible to purchase a replacement blade?
Wayne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 47
전체 시간: 4,824
