주요 콘텐츠로 건너뛰기
CHI Spin N Curl Rotating Curler Directional Buttons Replacement
필요한 것
  1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 3 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 4 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 5 단계, 이미지 3개 중 1개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 5 단계, 이미지 3개 중 2개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  7. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  8. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
  9. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Directional Buttons: 9 단계, 이미지 1개 중 1개
    • After the motherboard is removed, use the metal spudger to push and remove the directional buttons, and wipe underneath with a slightly damp alcohol cotton pad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Annalise White
회원 가입일: 10/26/22
530 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G7
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 32
전체 시간: 852
