주요 콘텐츠로 건너뛰기
CHI Spin N Curl Rotating Curler Rotating Barrel Replacement
필요한 것
  1. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 3 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 3 단계, 이미지 2개 중 2개
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 4 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 4 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 5 단계, 이미지 3개 중 1개 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 5 단계, 이미지 3개 중 2개 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 5 단계, 이미지 3개 중 3개
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Heating Element: 6 단계, 이미지 1개 중 1개
    • After following steps to open the CHI Spin N Curl, locate the heating element.
    • Remove screws on both sides of the heating element.
    • Once screws have been removed, then remove the heating element component.
    • Replace heating element once the original has been removed.
  7. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Rotating Barrel: 7 단계, 이미지 1개 중 1개
    • Remove all visible screws located near the barrel of the CHI Spin N Curl utilizing a Phillips #00 screwdriver.
    • Screws will be small and black.
  8. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 8 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 8 단계, 이미지 2개 중 2개
    • Remove all screws located near wires using a Phillips #00 screwdriver.
    • Once all surrounding screws have been removed, detach the rotating barrel.
    • Gently remove the rotating barrel and replace once removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Annalise White
회원 가입일: 10/26/22
530 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G7
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 803
