주요 콘텐츠로 건너뛰기
CHUWI GemiBook XPro Fan Replacement
필요한 것
  1. CHUWI GemiBook XPro Fan Replacement, Lower Case: 1 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement, Lower Case: 1 단계, 이미지 2개 중 2개
    • Discharge the battery below 25%, since a charged lithium-ion battery is a potential safety hazard. Fully power down the laptop and unplug any peripheries.
    • Orient the device to where you can see the bottom of the case.
    • Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
  2. CHUWI GemiBook XPro Fan Replacement: 2 단계, 이미지 3개 중 1개 CHUWI GemiBook XPro Fan Replacement: 2 단계, 이미지 3개 중 2개 CHUWI GemiBook XPro Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap between the lower case and the chassis.
    • Pry along the entire perimeter of the laptop until the lower case fully releases.
    • Lift the lower case up and off of the chassis.
  3. CHUWI GemiBook XPro Fan Replacement, Battery: 3 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Peel off the black tape on the upper-right side of the motherboard.
  4. CHUWI GemiBook XPro Fan Replacement: 4 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  5. CHUWI GemiBook XPro Fan Replacement: 5 단계, 이미지 3개 중 1개 CHUWI GemiBook XPro Fan Replacement: 5 단계, 이미지 3개 중 2개 CHUWI GemiBook XPro Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  6. CHUWI GemiBook XPro Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  7. CHUWI GemiBook XPro Fan Replacement: 7 단계, 이미지 3개 중 1개 CHUWI GemiBook XPro Fan Replacement: 7 단계, 이미지 3개 중 2개 CHUWI GemiBook XPro Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the battery up and out of the chassis.
  8. CHUWI GemiBook XPro Fan Replacement, Fan: 8 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement, Fan: 8 단계, 이미지 2개 중 2개
    • Use a spudger to push the fan connector out of its socket.
  9. CHUWI GemiBook XPro Fan Replacement: 9 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement: 9 단계, 이미지 2개 중 2개
    • The copper piping can be damaged easily, so take care not to bend it.
    • Carefully peel back the black tape on the radiator.
  10. CHUWI GemiBook XPro Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the two 4.2 mm screws that secure the fan.
  11. CHUWI GemiBook XPro Fan Replacement: 11 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Gently lift the fan out of the chassis, with care not to strain the connected wire.
  12. CHUWI GemiBook XPro Fan Replacement: 12 단계, 이미지 2개 중 1개 CHUWI GemiBook XPro Fan Replacement: 12 단계, 이미지 2개 중 2개
    • Gently remove the fan cable from under other wires and fully remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Siller
회원 가입일: 08/28/24
277 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 90
