주요 콘텐츠로 건너뛰기
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
필요한 것
  1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: 1 단계, 이미지 1/3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: 1 단계, 이미지 2/3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: 1 단계, 이미지 3/3
  2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 2 단계, 이미지 1/1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 3 단계, 이미지 1/3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 3 단계, 이미지 2/3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 3 단계, 이미지 3/3
    • Remove the plastic rings from the keycap.
  4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 4 단계, 이미지 1/2 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 4 단계, 이미지 2/2
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shiva Empranthiri
회원 가입일: 10/12/14
781 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 회원
CPSU-MANESS-F14S6G23
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,944
