소개
This guide will go over how to replace the switches on a CM Quickfire Rapid keyboard.
필요한 것
Remove the keycap of the key whose switch you'd like to replace by following the small keycap replacement guide or large keycap replacement guide.
Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard.
Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board.
Desolder the joints holding the switch to the board.
Remove the switch and solder the new switch in place.
다른 9명이 해당 안내서를 완성하였습니다.
