주요 콘텐츠로 건너뛰기
CM Storm QuickFire Rapid Switch Replacement
필요한 것
  1. CM Storm QuickFire Rapid Switch Replacement, Switch: 1 단계, 이미지 2개 중 1개 CM Storm QuickFire Rapid Switch Replacement, Switch: 1 단계, 이미지 2개 중 2개
  2. CM Storm QuickFire Rapid Switch Replacement, Remove screw on back of keyboard (labeled do not remove): 2 단계, 이미지 2개 중 1개 CM Storm QuickFire Rapid Switch Replacement, Remove screw on back of keyboard (labeled do not remove): 2 단계, 이미지 2개 중 2개
    • Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard.
    • This will void your warranty!
    • When inserting the screw after replacing the switch, make sure to not screw in too tight. This may cause erratic behavior with the keyboard.
  3. CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: 3 단계, 이미지 3개 중 1개 CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: 3 단계, 이미지 3개 중 2개 CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: 3 단계, 이미지 3개 중 3개
    • Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
  4. CM Storm QuickFire Rapid Switch Replacement, Opening Back Panel: 4 단계, 이미지 2개 중 1개 CM Storm QuickFire Rapid Switch Replacement, Opening Back Panel: 4 단계, 이미지 2개 중 2개
    • Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board.
    • Do not put strain on the ribbon cable when lifting the bottom panel.
  5. CM Storm QuickFire Rapid Switch Replacement, Detaching SIL Connector: 5 단계, 이미지 2개 중 1개 CM Storm QuickFire Rapid Switch Replacement, Detaching SIL Connector: 5 단계, 이미지 2개 중 2개
    • Detach the 4-pin cable from the bottom panel of the keyboard.
  6. CM Storm QuickFire Rapid Switch Replacement, Desolder Switch Solder Joints: 6 단계, 이미지 1개 중 1개
    • Desolder the joints holding the switch to the board.
    • Remove the switch and solder the new switch in place.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew
회원 가입일: 10/12/14
321 평판
안내서 2개를 작성함
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 회원
CPSU-MANESS-F14S6G23
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 46
전체 시간: 16,972
