주요 콘텐츠로 건너뛰기
CR-10 V2 Linear Rail Kit Hotend Installation
필요한 것
  1. CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: 1 단계, 이미지 3개 중 1개 CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: 1 단계, 이미지 3개 중 2개 CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: 1 단계, 이미지 3개 중 3개
    • Remove the Hotend cover screw
    • Remove the Hotend mounting screws
  2. CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: 2 단계, 이미지 3개 중 1개 CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: 2 단계, 이미지 3개 중 2개 CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: 2 단계, 이미지 3개 중 3개
    • Loosen Idler pulley bracket screws and remove the idler pulley bracket
    • Remove the belt
    • Remove the lower V-slot wheel bolt from X-carriage
  3. CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: 3 단계, 이미지 3개 중 1개 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: 3 단계, 이미지 3개 중 2개 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: 3 단계, 이미지 3개 중 3개
    • Follow the table for the recommended mounting locations
    • Take note to skip 2 holes between fasteners, and make sure to mirror this process from each of the end of the rail until you meet in the middle.
    • For rails with an odd number of mounting holes, the pattern will overlap in the middle
    • For rails with an even number of mounting holes, the pattern will be continued across the rail
    • Pre-install all the M3x8 SHCS screw and Sliding T-nuts
    • Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
    • The guide helps to slide the T-nuts into the extrusion
  4. CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: 4 단계, 이미지 3개 중 1개 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: 4 단계, 이미지 3개 중 2개 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: 4 단계, 이미지 3개 중 3개
    • Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
    • Use both Linear rail Guide to center the rail to the Aluminum extrusion
    • Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
  5. CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: 5 단계, 이미지 3개 중 1개 CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: 5 단계, 이미지 3개 중 2개 CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: 5 단계, 이미지 3개 중 3개
    • Belt adaptor
    • 4x M3x8 SHCS
    • 3x M3 split washers
    • M3 Hex nuts
    • Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
    • Push up on the belt bracket, it is square against the bottom of the carriage block.
    • Note: If screws will not start, threading in. Spin the screws counterclockwise until you hear a click, and then tighten the screws evenly in an X pattern until they are fully tightened. This is to ensure that the threads do not get damaged.
    • Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
  6. CR-10 V2  Linear Rail Kit Hotend Installation, Linear Rail Kit Hotend Install: 6 단계, 이미지 1개 중 1개
    • All Stock hotend and extruder mounting screws are re-used for the CR10 V2/V2
    • M3x6 BHCS (+2mm longer than stock) screws are used to mount the stock Bl Touch bracket.
결론
작성자
1다른 기여자 명과 함께
AJ Pereira
회원 가입일: 05/29/20
2,735 평판
안내서 16개를 작성함
Tiny Machines 3D Tiny Machines 3D 회원
Community
5 회원들
안내서 41개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 2,269
