주요 콘텐츠로 건너뛰기
CR-10S PRO Y Axis Linear Rail Kit Installation
필요한 것
  1. CR-10S PRO Y Axis Linear Rail Kit Installation, Machine Prep for linear rail kit: 1 단계, 이미지 1개 중 1개
    • Remove Bed leveling knobs
    • Be careful when lifting the bed off the Y Carriage. The springs may fall when lifting the bed up.
    • Lift bed and set to the back left side of the printer
  2. CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: 2 단계, 이미지 3개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: 2 단계, 이미지 3개 중 2개 CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: 2 단계, 이미지 3개 중 3개
    • Note: uses the stock CR10S Pro Y carriage with Vslot wheels assembly to keep the rails aligned while replacing the frame bolts
    • Remove with M5X30 SHCS one at a time
    • Replace with M5X30 BHCS
    • Slide Y carriage off from the front of the machine
  3. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Prep Instructions: 3 단계, 이미지 1개 중 1개
    • Remove from packaging
    • Note, do not touch the rail directly with your hands.
    • Wipe down rail with a lint free cloth
    • Add grease to the grease port on each side of the rail
  4. CR-10S PRO Y Axis Linear Rail Kit Installation: 4 단계, 이미지 3개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation: 4 단계, 이미지 3개 중 2개 CR-10S PRO Y Axis Linear Rail Kit Installation: 4 단계, 이미지 3개 중 3개
    • Pre-insert Spring loaded and use an Allen wrench or screwdriver to help align
    • M3 Spring loaded T-nut
    • Use the circled Rail mounting positions
    • 16x M3x8 SHCS
    • Picture with MGN guide on rail
  5. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: 5 단계, 이미지 2개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: 5 단계, 이미지 2개 중 2개
    • Tighten the screws evenly in an X shape
    • 4x Adapter Plate
    • 16x M3x6 FHCS
  6. CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: 6 단계, 이미지 3개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: 6 단계, 이미지 3개 중 2개 CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: 6 단계, 이미지 3개 중 3개
    • Remove all Vslot wheels and bolts
    • Install endstop Trigger at this location
    • Picture 2 shows endstop Trigger install
    • M5x35 SHCS
    • 3x Stock Vslot wheel spacers
    • M5 Nylon Ring Lock Nut
  7. CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: 7 단계, 이미지 3개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: 7 단계, 이미지 3개 중 2개 CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: 7 단계, 이미지 3개 중 3개
    • Belt mounting holes goes on the right side of the priter
    • Left side screws
    • Some early kits are drilled and taped for M5 Screws. The M4x8 FHCS is substituted for a M5x10 FHCS and the M4x10 BHCS substituted for M5x10 BHCS.
    • 2x M4x8 FHCS
    • Right screw stack order
    • M4x10 BHCS - M4 washer - M4 Large OD washer
    • Tightened the left side screws first
  8. CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: 8 단계, 이미지 3개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: 8 단계, 이미지 3개 중 2개 CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: 8 단계, 이미지 3개 중 3개
    • Belt Bracket Spacer
    • 2x M4x20 SHCS
  9. CR-10S PRO Y Axis Linear Rail Kit Installation, Endstop Braket mounting hardware Change: 9 단계, 이미지 1개 중 1개
    • Remove the stock endstop bracket screw
    • Replace endstop bracket mount screw with:
    • M3x10 SHCS, M3 Washer and M3 Sliding tnut
  10. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: 10 단계, 이미지 2개 중 1개 CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: 10 단계, 이미지 2개 중 2개
    • M5*10 BHCS
    • Acrylic stopper
  11. CR-10S PRO Y Axis Linear Rail Kit Installation, EndStop adjustment: 11 단계, 이미지 1개 중 1개
    • Adjust the Endstop position by sliding the endstop back until the nozzle tip lines up with the front edge of the bed when the endstop triggers.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
AJ Pereira
회원 가입일: 05/29/20
2,735 평판
안내서 16개를 작성함
Tiny Machines 3D Tiny Machines 3D 회원
Community
5 회원들
안내서 41개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 88
전체 시간: 4,759
