주요 콘텐츠로 건너뛰기
CR-10S/DDX Linear Rail Kit Hotend Installation
필요한 것
  1. CR-10S/DDX Linear Rail Kit Hotend Installation, Hotend Removal down: 1 단계, 이미지 1/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Hotend Removal down: 1 단계, 이미지 2/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Hotend Removal down: 1 단계, 이미지 3/3
    • Remove the Hotend cover screw
    • Remove the Hotend mounting screws
  2. CR-10S/DDX Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: 2 단계, 이미지 1/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: 2 단계, 이미지 2/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: 2 단계, 이미지 3/3
    • Loosen Idler pulley bracket screws and remove the idler pulley bracket
    • Remove the belt
    • Remove the lower V-slot wheel bolt from X-carriage
  3. CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: 3 단계, 이미지 1/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: 3 단계, 이미지 2/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: 3 단계, 이미지 3/3
    • Follow the table for the recommended mounting locations
    • Take note to skip 2 holes between fasteners, and make sure to mirror this process from each of the end of the rail until you meet in the middle.
    • For rails with an odd number of mounting holes, the pattern will overlap in the middle
    • For rails with an even number of mounting holes, the pattern will be continued across the rail
    • Pre-install all the M3x8 SHCS screw and Sliding T-nuts
    • Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
    • The guide helps to slide the T-nuts into the extrusion
  4. CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting the Rail: 4 단계, 이미지 1/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting the Rail: 4 단계, 이미지 2/3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting the Rail: 4 단계, 이미지 3/3
    • Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
    • Use both Linear rail Guide to center the rail to the Aluminum extrusion
    • Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
  5. CR-10S/DDX Linear Rail Kit Hotend Installation, X Carriage install: 5 단계, 이미지 1/3 CR-10S/DDX Linear Rail Kit Hotend Installation, X Carriage install: 5 단계, 이미지 2/3 CR-10S/DDX Linear Rail Kit Hotend Installation, X Carriage install: 5 단계, 이미지 3/3
    • Belt adaptor
    • 4x M3x8 SHCS
    • 3x M3 split washers
    • M3 Hex nuts
    • Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
    • Push up on the belt bracket, it is square against the bottom of the carriage block.
    • Note: If screws will not start, threading in. Spin the screws counterclockwise until you hear a click, and then tighten the screws evenly in an X pattern until they are fully tightened. This is to ensure that the threads do not get damaged.
    • Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
  6. CR-10S/DDX Linear Rail Kit Hotend Installation, Stock Hotend Install: 6 단계, 이미지 1/1
    • BL Touch and Fan Cover
    • M3x8 SHCS (2 mm longer than stock)
    • This screw replaces the M3x8 SHCS mount screw
    • M3x14 SHCS (8-10 mm longer than stock)
    • Hotend mounting screws
    • M3x22 SHCS (6 mm longer than stock) (Stock hotend)
    • M3x22 FHCS (6 mm longer than stock) (Stock hotend)
  7. CR-10S/DDX Linear Rail Kit Hotend Installation, DDX Install: 7 단계, 이미지 1/1
    • M3x28 SHCS & 2 Split lock washer(6 mm longer than stock) (Stock hotend)
결승점
다른 2명이 해당 안내서를 완성하였습니다.
AJ Pereira
회원 가입일: 05/29/20
2,679 평판
안내서 16개 작성하였습니다
Tiny Machines 3D Tiny Machines 3D 회원
Community
5 회원들
안내서 40개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 21
전체 시간: 1,608
