소개
HE Adaptor Plate stock CR10/S or DDX (for all X-axis linear rail kits) installation guide.
필요한 것
Loosen Idler pulley bracket screws and remove the idler pulley bracket
Remove the belt
Remove the lower V-slot wheel bolt from X-carriage
Follow the table for the recommended mounting locations
For rails with an odd number of mounting holes, the pattern will overlap in the middle
For rails with an even number of mounting holes, the pattern will be continued across the rail
Pre-install all the M3x8 SHCS screw and Sliding T-nuts
Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
The guide helps to slide the T-nuts into the extrusion
Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
Use both Linear rail Guide to center the rail to the Aluminum extrusion
Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
Belt adaptor
4x M3x8 SHCS
3x M3 split washers
M3 Hex nuts
Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
BL Touch and Fan Cover
M3x8 SHCS (2 mm longer than stock)
M3x14 SHCS (8-10 mm longer than stock)
Hotend mounting screws
M3x22 SHCS (6 mm longer than stock) (Stock hotend)
M3x22 FHCS (6 mm longer than stock) (Stock hotend)
다른 한 분이 해당 안내서를 완성하였습니다.
