필요한 것
Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
Once that the screws are removed, the cover will come down.
Now with more room to remove it, slide the two plastic tabs together.
When the two plastic tabs are in the middle pull the filter cover down.
Remove the filter.
Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
WhoDat?님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
