주요 콘텐츠로 건너뛰기
Cabinet Door Butt Hinge Replacement
필요한 것
  1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: 1 단계, 이미지 1개 중 1개
    • Determine where the cabinet needs repair: on the top or bottom hinge.
  2. Cabinet Door Butt Hinge Replacement: 2 단계, 이미지 1개 중 1개
    • Measure the hinge to make sure you have the correct size of your butt hinge.
    • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
  3. Cabinet Door Butt Hinge Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
    • Keep the screws nearby; you will need them later.
  4. Cabinet Door Butt Hinge Replacement: 4 단계, 이미지 1개 중 1개
    • Align the cabinet door to stand straight with any surrounding cabinets.
  5. Cabinet Door Butt Hinge Replacement: 5 단계, 이미지 1개 중 1개
    • Place the new hinge where the previous one was. Align the holes together.
  6. Cabinet Door Butt Hinge Replacement: 6 단계, 이미지 1개 중 1개
    • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
결론
If the door closes parallel to any surrounding cabinets, your fix is complete!
작성자
2다른 기여자 명과 함께
Laura Carew
회원 가입일: 10/05/23
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 50
전체 시간: 1,084
