주요 콘텐츠로 건너뛰기
Cabinet Door Hinge Replacement
필요한 것
  1. Cabinet Door Hinge Replacement, Hinge: 1 단계, 이미지 1/1
    • Remove the old screws to take the hinge off.
  2. Cabinet Door Hinge Replacement: 2 단계, 이미지 1/3 Cabinet Door Hinge Replacement: 2 단계, 이미지 2/3 Cabinet Door Hinge Replacement: 2 단계, 이미지 3/3
    • Take the hinge off the cabinet door.
  3. Cabinet Door Hinge Replacement: 3 단계, 이미지 1/1
    • Align the new hinge on the cabinet so that it is even and level and will open and close correctly.
  4. Cabinet Door Hinge Replacement: 4 단계, 이미지 1/2 Cabinet Door Hinge Replacement: 4 단계, 이미지 2/2
    • Insert and screw in the screw closest to the inside of the cabinet.
    • The innermost screw should be fastened first because it's the hardest to get to once the other screws are placed.
    • Screw in the rest of the screws until the hinge is in place.
  5. Cabinet Door Hinge Replacement: 5 단계, 이미지 1/1
    • The hinge is now replaced and the cabinet can shut all the way.
결승점
McKenna Harris
회원 가입일: 10/23/20
121 평판
안내서 1개 작성함
Texas Tech, Team S9-G4, Cowan Fall 2020 Texas Tech, Team S9-G4, Cowan Fall 2020 회원
TTU-COWAN-F20S9G4
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 36
전체 시간: 637
