주요 콘텐츠로 건너뛰기
Cabinet Magnetic Catch Replacement
필요한 것
  1. Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: 1 단계, 이미지 2개 중 1개 Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: 1 단계, 이미지 2개 중 2개
    • Remove two screws from the the old magnetic catch using a Phillips #0 screwdriver.
    • Remove the magnetic catch from the shelf.
    • It is recommended you use a stubby screwdriver since you will be dealing with tight spaces of the cabinet shelf.
  2. Cabinet Magnetic Catch Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screws securing the plates to the cabinet doors using a Phillips #0 screwdriver. Remove the plates.
    • Do this on the both sides.
  3. Cabinet Magnetic Catch Replacement: 3 단계, 이미지 3개 중 1개 Cabinet Magnetic Catch Replacement: 3 단계, 이미지 3개 중 2개 Cabinet Magnetic Catch Replacement: 3 단계, 이미지 3개 중 3개
    • Place the new magnetic catch on the center of the shelf cabinet.
    • Ensure it is adjusted carefully by moving its width halfway out of the cabinet and aligned on each side.
  4. Cabinet Magnetic Catch Replacement: 4 단계, 이미지 1개 중 1개
    • With your graphite pencil, mark the location of the screw holes so you know exactly where you placed it in case you get lost.
  5. Cabinet Magnetic Catch Replacement: 5 단계, 이미지 1개 중 1개
    • Screw in two 10 mm screws on the new magnetic catch using a Phillips #0 screwdriver to secure it in place.
    • Ensure that you are maintaining alignment of the magnetic catch with the help of Step 4. Otherwise, you will repeat Step 3.
    • You may reuse the old screws from the removal in Step 1 to install the new magnetic catch.
  6. Cabinet Magnetic Catch Replacement: 6 단계, 이미지 1개 중 1개
    • Close the cabinet and mark down the side of the cabinet door using a graphite pencil.
    • Do this on the other side.
  7. Cabinet Magnetic Catch Replacement: 7 단계, 이미지 1개 중 1개
    • Screw in one 5mm screw on the new magnetic plate using a Phillips #0 screwdriver to secure it in place on one side of the cabinet door.
    • Ensure that you are maintaining alignment of the magnetic plates with the help of Step 6 and old screw holes.
    • Do this step on the other side with the second 5mm screw.
    • You may reuse the old screws from the removal in Step 2 to install the new magnetic plates.
  8. Cabinet Magnetic Catch Replacement: 8 단계, 이미지 3개 중 1개 Cabinet Magnetic Catch Replacement: 8 단계, 이미지 3개 중 2개 Cabinet Magnetic Catch Replacement: 8 단계, 이미지 3개 중 3개
    • Test the cabinet magnetic catch by closing it.
    • You are finished when the cabinet stays closed after letting your hands go.
결론
You have finished the replacement of cabinet magnetic catch.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brian Hegina
회원 가입일: 06/30/21
184 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 57
전체 시간: 4,628
