주요 콘텐츠로 건너뛰기
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: 1 단계, 이미지 1/1
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: 2 단계, 이미지 1/3 Calculator is Stuck While Graphing: 2 단계, 이미지 2/3 Calculator is Stuck While Graphing: 2 단계, 이미지 3/3
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: 3 단계, 이미지 1/1
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: 4 단계, 이미지 1/2 Calculator is Stuck While Graphing: 4 단계, 이미지 2/2
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
결론
It is always a good idea to make sure your graph will display a good window.
John Baek
회원 가입일: 09/27/12
31 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 회원
CPSU-FORTE-F12S7G52
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,956
