주요 콘텐츠로 건너뛰기
Cambridge Audio A3i Motherboard Replacement
필요한 것
  1. Cambridge Audio A3i Motherboard Replacement, Case: 1 단계, 이미지 1/1
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Motherboard Replacement: 3 단계, 이미지 1/2 Cambridge Audio A3i Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Motherboard Replacement: 4 단계, 이미지 1/1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. Cambridge Audio A3i Motherboard Replacement: 6 단계, 이미지 1/1
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Cambridge Audio A3i Motherboard Replacement: 7 단계, 이미지 1/2 Cambridge Audio A3i Motherboard Replacement: 7 단계, 이미지 2/2
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Colby
회원 가입일: 04/15/10
338 평판
안내서 3개 작성하였습니다
Cal Poly, Team 28-36, Regan Spring 2010 Cal Poly, Team 28-36, Regan Spring 2010 회원
CPSU-REGAN-S10S28G36
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 29
전체 시간: 6,624
