소개
This guide describes the steps necessary to replace the motherboard of the system. This board contains the circuitry for the amplification, power, and output.
부품
지정된 부품이 없습니다.
Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
Remove the green grounding wire from the mounting screw.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
