소개
In this guide we will replace the power cord and the transformer The transformer is the large, heavy device that converts the relatively high 220V input voltage into a lower voltage for the amplifier.
필요한 것
Carefully de-solder ends of power cord from circuit board.
Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
Finally, pull the power cord through the rear panel to completely remove it.
다른 6명이 해당 안내서를 완성하였습니다.
