이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
In this guide we will replace the power cord and the transformer The transformer is the large, heavy device that converts the relatively high 220V input voltage into a lower voltage for the amplifier.
필요한 것
Carefully de-solder ends of power cord from circuit board.
Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
Finally, pull the power cord through the rear panel to completely remove it.
다른 5명이 해당 안내서를 완성하였습니다.
