이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove 2 screws on rear of device. Slide top cover up and back from main case.
Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
It may require some wiggling, but it should slip out of the hole and then off of the cord.
Carefully de-solder ends of power cord from circuit board.
Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
Finally, pull the power cord through the rear panel to completely remove it.
Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
다른 5명이 해당 안내서를 완성하였습니다.
