주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
필요한 것
    1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 1 단계, 이미지 2개 중 1개 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 1 단계, 이미지 2개 중 2개
      • Pull back the six screw covers on the bottom of the device.
      • Starting from the screw covers, peel the casing away from the bottom plate.
      댓글 쓰기
    1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: 2 단계, 이미지 1개 중 1개
      • Unscrew the five 11.5mm Phillips screws on the bottom plate.
      댓글 쓰기
    2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
      댓글 쓰기
    3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 4 단계, 이미지 1개 중 1개
      • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
      • There are wires connected to both plates so do this step with care.
      댓글 쓰기
    4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 5 단계, 이미지 1개 중 1개
      • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
      • Remove the brace that holds the battery in place.
      댓글 쓰기
    5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 6 단계, 이미지 1개 중 1개
      • Separate the battery from the bottom plate and set the bottom plate aside.
      댓글 쓰기
    6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 7 단계, 이미지 1개 중 1개
      • With some force, push the motherboard straight in toward the center of the device.
      댓글 쓰기
    7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 8 단계, 이미지 1개 중 1개
      • Pull the motherboard straight out of the device.
      • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
      댓글 쓰기
    8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 9 단계, 이미지 1개 중 1개
      • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
      댓글 쓰기
    1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
      • Unplug the wires that connect the speakers to the motherboard.
      댓글 쓰기
    2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 11 단계, 이미지 1개 중 1개
      • Unplug the thin white cable connected to the buttons.
      댓글 쓰기
    3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 12 단계, 이미지 2개 중 1개 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 12 단계, 이미지 2개 중 2개
      • Desolder the wires that connect the LED to the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Farshad Mohebban
회원 가입일: 02/10/16
524 평판
안내서 4개를 작성함
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 회원
USFT-NANCE-S16S1G1
4 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 2,114
