주요 콘텐츠로 건너뛰기
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
필요한 것
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 1 단계, 이미지 1/2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 1 단계, 이미지 2/2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: 2 단계, 이미지 1/1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 3 단계, 이미지 1/1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 4 단계, 이미지 1/1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 5 단계, 이미지 1/1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 6 단계, 이미지 1/1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 7 단계, 이미지 1/1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 8 단계, 이미지 1/1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 9 단계, 이미지 1/1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: 10 단계, 이미지 1/1
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 11 단계, 이미지 1/1
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 12 단계, 이미지 1/2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 12 단계, 이미지 2/2
    • Desolder the wires that connect the LED to the motherboard.
결론
Farshad Mohebban
회원 가입일: 02/10/16
524 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 회원
USFT-NANCE-S16S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,884
