주요 콘텐츠로 건너뛰기
Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement
필요한 것
  1. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Rubber Casing: 1 단계, 이미지 1/1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 2 단계, 이미지 1/1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 3 단계, 이미지 1/1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 4 단계, 이미지 1/1
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Speaker Grill: 5 단계, 이미지 1/1
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 6 단계, 이미지 1/1
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 7 단계, 이미지 1/1
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 8 단계, 이미지 1/1
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 9 단계, 이미지 1/1
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 10 단계, 이미지 1/2 Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: 10 단계, 이미지 2/2
    • Finally, bend the speaker cover upward and it will slide out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Farshad Mohebban
회원 가입일: 02/10/16
524 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 회원
USFT-NANCE-S16S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 941
