  1. The check engine light is on
    • The check engine light is on
  2. Hooking up the scan tool to find what is wrong The scan code is: p1391 which is cam shaft sensor code .
    • Hooking up the scan tool to find what is wrong
    • The scan code is: p1391 which is cam shaft sensor code .
  3. unplug the senor wire and get a tiny ranch and take the two pots off
    • unplug the senor wire and get a tiny ranch and take the two pots off
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Pull the sensor straight off
    • Pull the sensor straight off
  6. buy a new sensor
    • buy a new sensor
  7. Put the sensor in the same direction that was pointed it when you take it off
    • Put the sensor in the same direction that was pointed it when you take it off
  8. Tighten the two pots so it does not slip and plug back it
    • Tighten the two pots so it does not slip and plug back it
  9. Get the scan tools and reset it so the check engine light goes off Turn the key to on position Select erase code
    • Get the scan tools and reset it so the check engine light goes off
    • Turn the key to on position
    • Select erase code
    • Hit yes
  10. the check engine light is off
    • the check engine light is off
결론
adel_hydey
회원 가입일: 2018년 03월 06일
361 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 21
