주요 콘텐츠로 건너뛰기
Canary CAN100USBK Audio and USB PCB Board Replacement
필요한 것
  1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: 1 단계, 이미지 1/2 Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: 1 단계, 이미지 2/2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Audio and USB PCB Board Replacement: 2 단계, 이미지 1/1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Audio and USB PCB Board Replacement: 3 단계, 이미지 1/3 Canary CAN100USBK Audio and USB PCB Board Replacement: 3 단계, 이미지 2/3 Canary CAN100USBK Audio and USB PCB Board Replacement: 3 단계, 이미지 3/3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Audio and USB PCB Board Replacement: 4 단계, 이미지 1/2 Canary CAN100USBK Audio and USB PCB Board Replacement: 4 단계, 이미지 2/2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Audio and USB PCB Board Replacement: 5 단계, 이미지 1/2 Canary CAN100USBK Audio and USB PCB Board Replacement: 5 단계, 이미지 2/2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Audio and USB PCB Board Replacement, Ethernet PCB Board: 6 단계, 이미지 1/1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Audio and USB PCB Board Replacement: 7 단계, 이미지 1/2 Canary CAN100USBK Audio and USB PCB Board Replacement: 7 단계, 이미지 2/2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Audio and USB PCB Board Replacement: 8 단계, 이미지 1/1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
  9. Canary CAN100USBK Audio and USB PCB Board Replacement, Audio and USB PCB Board: 9 단계, 이미지 1/1
    • Using your fingernails, wiggle the power connector back and forth until it becomes loose.
    • Pull the power connector straight out of the socket.
    • Pull only on the power connector and not the wires themselves to prevent damage.
  10. Canary CAN100USBK Audio and USB PCB Board Replacement: 10 단계, 이미지 1/3 Canary CAN100USBK Audio and USB PCB Board Replacement: 10 단계, 이미지 2/3 Canary CAN100USBK Audio and USB PCB Board Replacement: 10 단계, 이미지 3/3
    • Use the spudger to pry up the retaining flap of the ZIF connector.
    • Disconnect the ribbon cable.
  11. Canary CAN100USBK Audio and USB PCB Board Replacement: 11 단계, 이미지 1/1
    • Remove the two Phillips #0 5mm screws.
  12. Canary CAN100USBK Audio and USB PCB Board Replacement: 12 단계, 이미지 1/2 Canary CAN100USBK Audio and USB PCB Board Replacement: 12 단계, 이미지 2/2
    • Pull the board away from the bottom casing by lifting the end closest to the chimney up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kristopher Gates
회원 가입일: 02/28/17
399 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017 회원
USFT-NANCE-S17S1G2
4 회원들
안내서 16개 작성하였습니다
댓글 2개
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
craig perrin - 답글
nice guide, need to buy the ep-cnc01bb-02 board which has the micro usb on it as mine is worn out... any ideas?
Billy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 800
