주요 콘텐츠로 건너뛰기
Canary CAN100USBK Ethernet PCB Board Replacement
필요한 것
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: 1 단계, 이미지 1/2 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: 1 단계, 이미지 2/2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: 2 단계, 이미지 1/1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: 3 단계, 이미지 1/3 Canary CAN100USBK Ethernet PCB Board Replacement: 3 단계, 이미지 2/3 Canary CAN100USBK Ethernet PCB Board Replacement: 3 단계, 이미지 3/3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: 4 단계, 이미지 1/2 Canary CAN100USBK Ethernet PCB Board Replacement: 4 단계, 이미지 2/2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: 5 단계, 이미지 1/2 Canary CAN100USBK Ethernet PCB Board Replacement: 5 단계, 이미지 2/2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: 6 단계, 이미지 1/1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: 7 단계, 이미지 1/2 Canary CAN100USBK Ethernet PCB Board Replacement: 7 단계, 이미지 2/2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: 8 단계, 이미지 1/1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
결론
Tommy Nguyen
회원 가입일: 02/28/17
597 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017 회원
USFT-NANCE-S17S1G2
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 912
