소개
To replace the scanner bar, the glass must first be removed, and then the scanner bar can be easily removed and replaced.
필요한 것
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hello Nick, thank you for the guide.
My CanoScan LiDE 220 has started to introduce a line down the middle of the page when I scan with VueScan. Not sure if this guide applies.
Mark Leung - 답글
