소개
This guide will show you how to remove the plastic frame from the case and how to remove the scanner glass to be replaced. A little force will be necessary but with care, this guide will be fairly easy.
필요한 것
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Can we replace any ordinary glass ? R there are any specifications for glass quality/type ?
