주요 콘텐츠로 건너뛰기
CanoScan LiDE 35 Square Port Removal
필요한 것
  1. CanoScan LiDE 35 Square Port Removal, Scanner Glass: 1 단계, 이미지 1/3 CanoScan LiDE 35 Square Port Removal, Scanner Glass: 1 단계, 이미지 2/3 CanoScan LiDE 35 Square Port Removal, Scanner Glass: 1 단계, 이미지 3/3
    • Slide plastic opening tool under the plastic.
    • Gently pry the plastic framing off the glass.
    • Repeat on the other side.
  2. CanoScan LiDE 35 Square Port Removal: 2 단계, 이미지 1/2 CanoScan LiDE 35 Square Port Removal: 2 단계, 이미지 2/2
    • Remove the front plastic frame.
  3. CanoScan LiDE 35 Square Port Removal: 3 단계, 이미지 1/3 CanoScan LiDE 35 Square Port Removal: 3 단계, 이미지 2/3 CanoScan LiDE 35 Square Port Removal: 3 단계, 이미지 3/3
    • Wedge the plastic opening tool under the glass.
    • Pull up against glass.
    • Slide the glass forward.
    • Remove the glass.
  4. CanoScan LiDE 35 Square Port Removal, Square Port: 4 단계, 이미지 1/3 CanoScan LiDE 35 Square Port Removal, Square Port: 4 단계, 이미지 2/3 CanoScan LiDE 35 Square Port Removal, Square Port: 4 단계, 이미지 3/3
    • Locate three screws on the grey shell.
    • Unscrew the three screws.
    • Separate the grey shell from case.
  5. CanoScan LiDE 35 Square Port Removal: 5 단계, 이미지 1/3 CanoScan LiDE 35 Square Port Removal: 5 단계, 이미지 2/3 CanoScan LiDE 35 Square Port Removal: 5 단계, 이미지 3/3
    • Separate the grey shell from square port.
  6. CanoScan LiDE 35 Square Port Removal: 6 단계, 이미지 1/3 CanoScan LiDE 35 Square Port Removal: 6 단계, 이미지 2/3 CanoScan LiDE 35 Square Port Removal: 6 단계, 이미지 3/3
    • Locate the ribbon cable on casing.
    • Remove the ribbon cable on casing.
  7. CanoScan LiDE 35 Square Port Removal: 7 단계, 이미지 1/1
    • Once the ribbon cable is removed, locate the square port.
    • Remove the square port.
결론
Shannon
회원 가입일: 10/28/13
364 평판
안내서 2개 작성하였습니다
Clemson, Team 1-89, Diaz Fall 2013 Clemson, Team 1-89, Diaz Fall 2013 회원
CLEM-DIAZ-F13S1G89
1 회원
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 888
