소개
If your CanoScan LiDE 35s scanner square port doesn’t work and needs to be removed, this guide is for you. In seven simple steps this guide will visually show you what parts need to be removed and how to remove them. At the end of this guide you will have removed the square port yourself. A screwdriver is needed for this removal.
필요한 것
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
거의 끝나갑니다!
결론
