소개
This guide demonstrates how to replace the top exterior shell for the Canon LV-7210. This repair may be necessary if the projector has sustained cosmetic damage. The only tool you will need for this guide is a screwdriver.
필요한 것
Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
