주요 콘텐츠로 건너뛰기
Canon AE-1 Light Filter Foam Replacement
필요한 것
  1. Canon AE-1 Light Filter Foam Replacement, Light Filter Foam: 1 단계, 이미지 1/1
    • Open the film compartment by pulling on the release pin.
    • Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
    • Then use Isopropyl Alcohol to assist in removing the old light filter foam.
  2. Canon AE-1 Light Filter Foam Replacement: 2 단계, 이미지 1/1
    • Placing light filter foam improperly could result in light exposure on film.
    • Cut the new light filter foam to size so it can fit in the slot.
    • Place the sticky side of the new strip of light filter foam over old foams location.
결론
To reassemble your device, follow these instructions.
다른 2명이 해당 안내서를 완성하였습니다.
Brad
회원 가입일: 10/04/11
47 평판
안내서 1개 작성함
UW Stout, Team 5-1, Zhou Fall 2011 UW Stout, Team 5-1, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S5G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 76
전체 시간: 13,083
