소개
We are removing the old light filter foam and replacing it with new foam in your Canon AE-1. This will help keep light out of the inner case so that it doesn't wreck the film.
필요한 것
Open the film compartment by pulling on the release pin.
Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
Then use Isopropyl Alcohol to assist in removing the old light filter foam.
거의 끝나갑니다!
To reassemble your device, follow these instructions.
결론
다른 2명이 해당 안내서를 완성하였습니다.
