주요 콘텐츠로 건너뛰기
Canon AE-1 SLR Lens Mount Replacement
필요한 것
  1. Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: 1 단계, 이미지 1/2 Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: 1 단계, 이미지 2/2
    • Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
    • The first set of screws is located on the front and bottom of the lens casing.
  2. Canon AE-1 SLR Lens Mount Replacement: 2 단계, 이미지 1/2 Canon AE-1 SLR Lens Mount Replacement: 2 단계, 이미지 2/2
    • Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
  3. Canon AE-1 SLR Lens Mount Replacement: 3 단계, 이미지 1/1
    • Remove the lens casing by pulling it away from the body of the camera.
  4. Canon AE-1 SLR Lens Mount Replacement: 4 단계, 이미지 1/1
    • Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
  5. Canon AE-1 SLR Lens Mount Replacement: 5 단계, 이미지 1/3 Canon AE-1 SLR Lens Mount Replacement: 5 단계, 이미지 2/3 Canon AE-1 SLR Lens Mount Replacement: 5 단계, 이미지 3/3
    • Pull the SLR lens mount away from the body of the camera.
    • Be aware that a pin will fall out when the SLR lens mount is removed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Joe Blumberg
회원 가입일: 10/04/11
213 평판
안내서 1개 작성함
UW Stout, Team 5-1, Zhou Fall 2011 UW Stout, Team 5-1, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S5G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 65
전체 시간: 11,626
