소개
If you're encountering issues as a result from the scanner bed, this is where you will want to start.
To replace the glass scanner bed, you must:
- Remove the two plastic bars that holds the scanner bed in place.
- Carefully remove the glass scanner bed to add the replacement.
필요한 것
Open up your Canon CanoScan N670U to an upright position.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
