소개
If you're having issues as a result of a dirty or faulty white document mat, this is where you will want to begin.
To remove the white document mat, you must:
- Carefully rip out the foam that's glued onto the cover.
- Glue in the replacement document mat.
필요한 것
거의 끝나갑니다!
To reassemble your device, ensure that the white document mat is firmly glued on.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
