주요 콘텐츠로 건너뛰기
Canon CanoScan N670U White Document Mat Replacement
필요한 것
  1. Canon CanoScan N670U White Document Mat Replacement, White Document Mat: 1 단계, 이미지 1/1
    • Open up the top of your Canon CanoScan N670U to this position.
  2. Canon CanoScan N670U White Document Mat Replacement: 2 단계, 이미지 1/1
    • The document mat is taped on to these four corners of the cover. These spots will be where we'll start removing the mat.
  3. Canon CanoScan N670U White Document Mat Replacement: 3 단계, 이미지 1/1
    • Gently peel the tape on each corner of the mat using your hands or an iFixit Tech Knife.
    • Be careful to not rip the foam while peeling.
  4. Canon CanoScan N670U White Document Mat Replacement: 4 단계, 이미지 1/1
    • Tape in your replacement document mat back onto the top cover of the scanner.
결론
To reassemble your device, ensure that the white document mat is firmly glued on.
다른 한 분이 해당 안내서를 완성하였습니다.
Stephen Bui
회원 가입일: 09/19/15
558 평판
안내서 4개 작성하였습니다
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G1
5 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 281
