주요 콘텐츠로 건너뛰기
Canon DM-100 microphone rattle noise fix
필요한 것
  1. Canon DM-100 microphone rattle noise fix, The Mic: 1 단계, 이미지 1/1
    • This is the rattly beast.
  2. Canon DM-100 microphone rattle noise fix, Getting in…: 2 단계, 이미지 1/1
    • You access the internals by removing the grill in the front, which is held in place by a small amount of adhesive.
    • Use a set of tweezers (or a pointy metallic object, I used a tiny screwdriver) and gently pull in a circular fashion not to destroy the metal girder.
  3. Canon DM-100 microphone rattle noise fix, The culprit: 3 단계, 이미지 1/2 Canon DM-100 microphone rattle noise fix, The culprit: 3 단계, 이미지 2/2
    • Canon has used an elastic band for vibration reduction of the directional "sound pipe" (seen as a circle behind the elastic band).
    • The pipe visible behind the elastic is supposed to be mounted toe the inner wall with the two marked circular joints.
    • These incredibly weak joints are bound to break as the rubber loses its elasticity.
  4. Canon DM-100 microphone rattle noise fix, Remove rubber band: 4 단계, 이미지 1/2 Canon DM-100 microphone rattle noise fix, Remove rubber band: 4 단계, 이미지 2/2
    • Rubber band is irreparable and needs to go. I scratched it out using a small, sharp screwdriver.
  5. Canon DM-100 microphone rattle noise fix, Clean slate: 5 단계, 이미지 1/1
    • The culprit of the rattling noise is now apparent. A plastic cylinder stretches through the whole of the microphone, enabling the microphones forward focused / directional sound.
    • When the rubber band breaks because of the bad joints, this thing hits the inner side of the cylinder.
  6. Canon DM-100 microphone rattle noise fix, Find stuffing: 6 단계, 이미지 1/3 Canon DM-100 microphone rattle noise fix, Find stuffing: 6 단계, 이미지 2/3 Canon DM-100 microphone rattle noise fix, Find stuffing: 6 단계, 이미지 3/3
    • I measured the internal diameter, and found that there in total was a void of about 2mm in between the tube and the mic cylinder.
    • After some searching, I found a 2mm thick foam sheet for about 50 cents at a hobbyist shop.
    • Use this to cut a small sheet of depth of about 2 cm and length matching the inner circumference.
  7. Canon DM-100 microphone rattle noise fix, Stuff it: 7 단계, 이미지 1/1
    • After some scissoring, you should have something that looks a bit like this.
  8. Canon DM-100 microphone rattle noise fix, Make it stick.: 8 단계, 이미지 1/1
    • Add a dab of glue around the foam to make sure it stays in place.
  9. Canon DM-100 microphone rattle noise fix, Glue and replace the grill and wind stopper: 9 단계, 이미지 1/1
    • Add a thin layer of glue to the yellow circle and reattach the grill and windstopper.
  10. Canon DM-100 microphone rattle noise fix, Done: 10 단계, 이미지 1/1
    • There! 190$ microphone fixed for less than a dollar.
    • The audio quality isn't affected at all.
결론
The DM-100 is a good, but expensive microphone for all Canon camcorders. The internal suspension is broken by design, and will render the microphone unusable after 2-3 years of use.
This fix is a permanent fix to Canons poor design. Since the pipe is solid, and the foam is only reaching about 2cm into the pipe, audio quality is not affected at all.
다른 한 분이 해당 안내서를 완성하였습니다.
Bonka
회원 가입일: 05/15/15
353 평판
안내서 2개 작성하였습니다
댓글 2개
Good work, good tutorial! Can you help me? I have DM-50. How to connect it to Mini Advanced Hot Shoe? Do you have an electric circuit DM-50?
raoul.luigend@gmail.com
raoul.luigend - 답글
Hi, Raoul. I’m not sure what you’re trying to accomplish on what sort of equipment. I don’t know the DM-50, but if you have a camera with the mini hot shoe like the Legria / Vixia, you just need to slide open the compartment on the top of the camera and insert the mic firmly into the hot shoe.
Bonka - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 887
