주요 콘텐츠로 건너뛰기
Canon EF 16-35mm f/2.8L USM Lens Mount Replacement
필요한 것
  1. Canon EF 16-35mm f/2.8L USM Lens Mount Replacement, Lens Mount: 1 단계, 이미지 2개 중 1개 Canon EF 16-35mm f/2.8L USM Lens Mount Replacement, Lens Mount: 1 단계, 이미지 2개 중 2개
    • If possible, try to work in an environment with minimal dust. The goal is to try to avoid dust from getting inside of the lens as much as possible.
    • Remove the two 3mm JIS #000 screws on the side of the lens mount.
    • Remove the four 8mm JIS #000 screws holding in the metal lens mount.
    • Do not pull up on the lens mount assembly. The contact assembly is still attached and you'd risk damaging the ribbon cable.
  2. Canon EF 16-35mm f/2.8L USM Lens Mount Replacement: 2 단계, 이미지 2개 중 1개 Canon EF 16-35mm f/2.8L USM Lens Mount Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift up the side opposite of the contact assembly.
    • Slide your finger (or plastic spudger tool) under the lens mount and pop off the back plastic cover off of the lens.
    • Pull the lens mount assembly up and away from the lens.
결론
첨부 문서
작성자
1다른 기여자 명과 함께
Zephosk
회원 가입일: 09/26/24
4,557 평판
안내서 27개를 작성함
LGBTQ Technicians LGBTQ Technicians 회원
Community
33 회원들
안내서 96개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 52
