주요 콘텐츠로 건너뛰기
Canon ELPH Z3 Camera Image Sensor Replacement
필요한 것
  1. Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: 1 단계, 이미지 3개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: 1 단계, 이미지 3개 중 2개 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: 1 단계, 이미지 3개 중 3개
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Image Sensor Replacement: 2 단계, 이미지 3개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement: 2 단계, 이미지 3개 중 2개 Canon ELPH Z3 Camera Image Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Image Sensor Replacement: 3 단계, 이미지 2개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Image Sensor Replacement: 4 단계, 이미지 3개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement: 4 단계, 이미지 3개 중 2개 Canon ELPH Z3 Camera Image Sensor Replacement: 4 단계, 이미지 3개 중 3개
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: 5 단계, 이미지 2개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: 5 단계, 이미지 2개 중 2개
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Image Sensor Replacement: 6 단계, 이미지 3개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement: 6 단계, 이미지 3개 중 2개 Canon ELPH Z3 Camera Image Sensor Replacement: 6 단계, 이미지 3개 중 3개
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Image Sensor Replacement: 7 단계, 이미지 2개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
  8. Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: 8 단계, 이미지 3개 중 1개 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: 8 단계, 이미지 3개 중 2개 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: 8 단계, 이미지 3개 중 3개
    • Pull away back screen base to reveal the image sensor.
    • Remove image sensor using a set of pliers.
결론
작성자
2다른 기여자 명과 함께
Katy Skillings
회원 가입일: 10/21/16
1 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G7
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 399
