주요 콘텐츠로 건너뛰기
Canon EOS 20D Secondary Control Board (C-Board 010) Replacement
필요한 것
  1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: 1 단계, 이미지 2개 중 1개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: 1 단계, 이미지 2개 중 2개
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove screws from under the eyepiece cap: 2 단계, 이미지 1개 중 1개
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: 3 단계, 이미지 3개 중 1개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: 3 단계, 이미지 3개 중 2개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: 3 단계, 이미지 3개 중 3개
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove bottom screws: 4 단계, 이미지 1개 중 1개
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: 5 단계, 이미지 3개 중 1개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: 5 단계, 이미지 3개 중 2개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: 5 단계, 이미지 3개 중 3개
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  6. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: 6 단계, 이미지 3개 중 1개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: 6 단계, 이미지 3개 중 2개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: 6 단계, 이미지 3개 중 3개
    • Disconnect all the indicated connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
    • Disconnect the two hidden connectors under the top connector indicated in pink.
    • Disconnect the third hidden connector.
  7. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: 7 단계, 이미지 2개 중 1개 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: 7 단계, 이미지 2개 중 2개
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alec M
회원 가입일: 05/08/16
1,468 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 1,491
