주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Pull up on both sides of the the eyepiece cap. It should come off with little pressure. Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Remove both screws hidden under the viewfinder eyepiece cap.
    • Remove both screws hidden under the viewfinder eyepiece cap.
  3. Peel off the rubber grip on the back by grasping one of the corners and pulling out. Once removed, a hidden screw is revealed. Remove both visible screws from the rear of the camera.
    • Peel off the rubber grip on the back by grasping one of the corners and pulling out.
    • Once removed, a hidden screw is revealed.
    • Remove both visible screws from the rear of the camera.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Remove both labeled screws from the bottom of the camera.
    • Remove both labeled screws from the bottom of the camera.
  6. When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board. Flip the lock on the flex cable connector up with a spudger. The front panel should pop off now that the cable has been disconnected.
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  7. Disconnect all the labeled connectors by opening their latches. Remove the flex cable that connects the logic board to the secondary control board. Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running to the connector.
    • Disconnect all the labeled connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running to the connector.
    • Disconnect the two hidden connectors under the top connector labeled in pink.
    • Disconnect the third hidden connector.
  8. Remove the three screws from the edges  of the board. Flip the board up and out so that the ground connection can be unscrewed.
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alec M
회원 가입일: 2016년 05월 08일
853 평판
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 189
