주요 콘텐츠로 건너뛰기
소개
Removing the grip is necessary to reach the battery door. This process is safe and easy.
부품
지정된 부품이 없습니다.
  1. Canon EOS 30 Grip Replacement, Front Panel: step 1, image 1 of 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Grip Replacement: step 2, image 1 of 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Grip Replacement: step 3, image 1 of 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Grip Replacement: step 4, image 1 of 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Grip Replacement, Top Panel: step 5, image 1 of 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 Grip Replacement: step 6, image 1 of 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 Grip Replacement: step 7, image 1 of 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 Grip Replacement: step 8, image 1 of 2 Canon EOS 30 Grip Replacement: step 8, image 2 of 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 Grip Replacement, Side Panel With Remote Control Socket: step 9, image 1 of 1
    • Remove two 6.5 mm black screws from the panel.
  10. Canon EOS 30 Grip Replacement: step 10, image 1 of 1
    • Remove the plastic remote control socket cap by pulling it straight out.
  11. Canon EOS 30 Grip Replacement: step 11, image 1 of 2 Canon EOS 30 Grip Replacement: step 11, image 2 of 2
    • Slide panel toward bottom of camera to remove.
  12. Canon EOS 30 Grip Replacement, Grip: step 12, image 1 of 1
    • Remove the two 5.5 mm screws from front of camera.
  13. Canon EOS 30 Grip Replacement: step 13, image 1 of 1
    • Remove grip panel.
결론
Jackie
회원 가입일: 2011년 04월 17일
236 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 22개 작성하였습니다
댓글 한 개
Didn't you forget the step to remove the bottom plate?
Sino Lino - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 3,456
