주요 콘텐츠로 건너뛰기
Canon EOS 30 LCD Screen Replacement
필요한 것
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: 5 단계, 이미지 1개 중 1개
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Canon EOS 30 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 1개 중 1개
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
  10. Canon EOS 30 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Lift LCD screen out of mount.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sterling Vinson
회원 가입일: 04/17/11
314 평판
안내서 5개를 작성함
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 22개를 작성함
2가이드 댓글
Thank's , your tutorial nice ... gracias
fajar - 답글
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 5,664
