주요 콘텐츠로 건너뛰기
Canon EOS 30 Lens Mount Rings
필요한 것
  1. Canon EOS 30 Lens Mount Rings, Front Panel: 1 단계, 이미지 1/1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Lens Mount Rings: 2 단계, 이미지 1/1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Lens Mount Rings: 3 단계, 이미지 1/1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Lens Mount Rings: 4 단계, 이미지 1/1
    • Remove the front panel by lifting it away from the camera's body.
    I need a video tutorial
    Abdullah dicky S - 답글
  5. Canon EOS 30 Lens Mount Rings, Lens Mount Rings: 5 단계, 이미지 1/1
    • Remove four 7.1 mm silver screws from lens mount ring.
  6. Canon EOS 30 Lens Mount Rings: 6 단계, 이미지 1/1
    • Remove outer mount ring.
    • The silver button may detach.
  7. Canon EOS 30 Lens Mount Rings: 7 단계, 이미지 1/1
    • Remove thin gold ring.
    • Correct orientation is pictured.
  8. Canon EOS 30 Lens Mount Rings: 8 단계, 이미지 1/1
    • Remove thin silver ring.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Antonia
회원 가입일: 04/17/11
124 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 22개 작성하였습니다
댓글 한 개
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
Patryk Granatowicz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 33
전체 시간: 5,491
