주요 콘텐츠로 건너뛰기
Canon EOS 30 Strap Loops Replacement
필요한 것
  1. Canon EOS 30 Strap Loops Replacement, Top Panel: 1 단계, 이미지 1/1
    • Slide the outer eyepiece upward to remove it.
  2. Canon EOS 30 Strap Loops Replacement: 2 단계, 이미지 1/1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  3. Canon EOS 30 Strap Loops Replacement: 3 단계, 이미지 1/1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  4. Canon EOS 30 Strap Loops Replacement: 4 단계, 이미지 1/2 Canon EOS 30 Strap Loops Replacement: 4 단계, 이미지 2/2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  5. Canon EOS 30 Strap Loops Replacement, Strap Loops: 5 단계, 이미지 1/2 Canon EOS 30 Strap Loops Replacement, Strap Loops: 5 단계, 이미지 2/2
    • Remove two 5.9 mm silver screws on top of camera to detach left strap loop (opposite grip).
  6. Canon EOS 30 Strap Loops Replacement: 6 단계, 이미지 1/2 Canon EOS 30 Strap Loops Replacement: 6 단계, 이미지 2/2
    • Remove one 8.5 mm silver screw (front) and one 5.45 mm silver screw (back) to remove strap loop near LCD screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Gonzalez
회원 가입일: 04/17/11
15 평판
안내서 1개 작성함
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 2,617
