주요 콘텐츠로 건너뛰기
Canon EOS 300 Back Lock-Release Lever Replacement
필요한 것
  1. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: 1 단계, 이미지 3개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: 1 단계, 이미지 3개 중 2개 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: 1 단계, 이미지 3개 중 3개
    • Open up the battery door.
  2. Canon EOS 300 Back Lock-Release Lever Replacement: 2 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: 3 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: 3 단계, 이미지 2개 중 2개
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Back Lock-Release Lever Replacement: 4 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Back Lock-Release Lever Replacement: 5 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement: 5 단계, 이미지 2개 중 2개
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: 6 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: 6 단계, 이미지 2개 중 2개
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Back Lock-Release Lever Replacement: 7 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement: 7 단계, 이미지 2개 중 2개
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Back Lock-Release Lever Replacement: 8 단계, 이미지 2개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: 9 단계, 이미지 3개 중 1개 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: 9 단계, 이미지 3개 중 2개 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: 9 단계, 이미지 3개 중 3개
    • Pull off the lever by pushing up from the bottom and pulling away from the bottom.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jordan Tang
회원 가입일: 01/24/14
605 평판
안내서 5개를 작성함
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 회원
CPSU-MANESS-W14S6G20
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 21
전체 시간: 2,238
